Speedo swap
lrmaniac
Speedo swap
Postby lrmaniac » Sat Jan 02, 2016 8:03 pm
Hi
If I wanted to change, at a later time, the speedometer from mph to kmh what do I need?
Just the speedo, just the cable? Are there special speedos for 900 tyres or special cables, or a special adaptor somewhere? Or anything else?
Re: Speedo swap
Postby helicalrider » Sat Jan 02, 2016 8:47 pm
http://www.ebay.co.uk/itm/Land-Rover-10 ... fAWZ2nMdkA
There are different speedos for Series Land Rovers and 1 Tons.
But the outer scale shows MPH and the inner shows KM/H. Why do you want to change?
A britsh vehicle with MPH speedo looks very nice.
Re: Speedo swap
Postby 22900013A » Sat Jan 02, 2016 10:36 pm
Earlier series vehicles do not normally have both scales, for example SEB only has MPH as does the cherrypicker. I suspect Joao-Pedros FC is the same.
You would only need to change the head, the cable and everything else remains the same. But where to find a KPH speedo suitable for 900-16 tyres?
lrmaniac
Re: Speedo swap
Postby lrmaniac » Sun Jan 03, 2016 12:32 am
My speedo only shows mph.
I don't think I'll have to change it. I'm convinced that it will pass MOT :| ...
It doesn't bother me...and if I'm not forced to change it, I'll keep it for now...
but since its a LHD, I'm used to see a Kmh speedo in front of me! :D
Since it's just the speedo on the dash, Where to find them?
Well, that was something I was hoping you could tell me!, since LR with 9.00/16 tyres over here are quite rare!
udo1-ton
Re: Speedo swap
Postby udo1-ton » Sun Jan 03, 2016 1:05 pm
http://www.johnrichardssurplus.co.uk/la ... 79198.html
It's not a bargain but...
There is anotherone on the Craddock site for a horrible sum...
http://www.johncraddockltd.co.uk/series ... -tyre.html
Regards, Udo
lrmaniac
Re: Speedo swap
Postby lrmaniac » Sun Jan 03, 2016 1:27 pm
Mine is an early SIIA, petrol...the speedo does not have the oil pressure/main beam/cold start lights on the speedo!
Part number is/was 520298->might have been replaced later for another number?
And those are obscene prices! :shock:
So unless I find one on ebay will be very dificult?
udo1-ton
Re: Speedo swap
Postby udo1-ton » Sun Jan 03, 2016 7:00 pm
All SIIa from 1968 onwards should have the speedo with the three lamps and all 1-tons are from the late era. Maybe someone made an exchange in the past.
Regards
Udo
lrmaniac
Re: Speedo swap
Postby lrmaniac » Mon Jan 04, 2016 11:35 am
udo1-ton wrote:All SIIa from 1968 onwards should have the speedo with the three lamps and all 1-tons are from the late era.
Ah, but mine is 63 Forward Control
udo1-ton
Re: Speedo swap
Postby udo1-ton » Mon Jan 04, 2016 4:51 pm
Aah okay, I didn't notice that, sorry.
Quite difficult to find one with km/h scale on.
Re: Speedo swap
Postby Wheeledbeast » Tue Jan 05, 2016 2:59 pm
Ouch Mr Craddock :shock: :!:
Users browsing this forum: No registered users and 14 guests
