Hi
If I wanted to change, at a later time, the speedometer from mph to kmh what do I need?
Just the speedo, just the cable? Are there special speedos for 900 tyres or special cables, or a special adaptor somewhere? Or anything else?
Speedo swap
- High range
Re: Speedo swap
http://www.ebay.co.uk/itm/Land-Rover-10 ... fAWZ2nMdkA
There are different speedos for Series Land Rovers and 1 Tons.
But the outer scale shows MPH and the inner shows KM/H. Why do you want to change?
A britsh vehicle with MPH speedo looks very nice.
Re: Speedo swap
Earlier series vehicles do not normally have both scales, for example SEB only has MPH as does the cherrypicker. I suspect Joao-Pedros FC is the same.
You would only need to change the head, the cable and everything else remains the same. But where to find a KPH speedo suitable for 900-16 tyres?
Re: Speedo swap
My speedo only shows mph.
I don't think I'll have to change it. I'm convinced that it will pass MOT
It doesn't bother me...and if I'm not forced to change it, I'll keep it for now...
but since its a LHD, I'm used to see a Kmh speedo in front of me!
Since it's just the speedo on the dash, Where to find them?
Well, that was something I was hoping you could tell me!, since LR with 9.00/16 tyres over here are quite rare!
Re: Speedo swap
http://www.johnrichardssurplus.co.uk/la ... 79198.html
It's not a bargain but...
There is anotherone on the Craddock site for a horrible sum...
http://www.johncraddockltd.co.uk/series ... -tyre.html
Regards, Udo
Regards, Udo
Re: Speedo swap
Mine is an early SIIA, petrol...the speedo does not have the oil pressure/main beam/cold start lights on the speedo!
Part number is/was 520298->might have been replaced later for another number?
And those are obscene prices!
So unless I find one on ebay will be very dificult?
Re: Speedo swap
All SIIa from 1968 onwards should have the speedo with the three lamps and all 1-tons are from the late era. Maybe someone made an exchange in the past.
Regards
Udo
Regards
Udo
Re: Speedo swap
Ah, but mine is 63 Forward Controludo1-ton wrote:All SIIa from 1968 onwards should have the speedo with the three lamps and all 1-tons are from the late era.
Re: Speedo swap
Aah okay, I didn't notice that, sorry.
Quite difficult to find one with km/h scale on.
Re: Speedo swap
Ouch Mr Craddock
Users browsing this forum: No registered users and 49 guests
