Different engines
Re: Different engines
Postby 22900013A » Sun Jul 21, 2013 8:23 pm
DML wrote:Not that im in a position to do anything about it just now, but Das do you have any 2.6 engine's looking for a new home? can you get parts easy enough to rebuild these engines if i came across a non runner for sale? cheers
:212C:
You need to speak to nutsaboutseries - I think he has some engines that could find their way into deserving new homes. He can also supply some parts, and Das does seem to know what he is doing in terms of working on them as well. ;) I usually take a trip up to Das once every six months or so, so if you sort something with Ben (nuts...) I can probably transport one as far as Castle Douglas if required.
Nutsaboutseries
Postby Nutsaboutseries » Mon Jul 22, 2013 11:53 am
I might have one or two kicking around.......
off the shelf parts are the problem going forward. nothing beyond the wit of man if you have the will and wallet.
1978 109" Fire Engine
1972 109" SW
1970 109" SW
1970 109" 1 Ton
1969 88" Air Portable
1967 109" 6 cyl
1967 2b FC 2.25D
1963 2a FC 2.25P
DML
Postby DML » Mon Jul 22, 2013 6:46 pm
Thankyou Dan for your very kind offer, i will bear this in mind. And Ben, if you don't mind me contacting you in the future to see if your willing to sell an engine and associated bits that would be appreciated (i'm going to exhaust all possibilities of finding one locally.) I think i'm going to need just about all the associated items e.g airbox, pipework, throttle linkage, cables, fuel pump? etc as all these were either butchered or thrown away when the previous owner scrapped the 2.6 and put in the diesel! i do however have the bellhousing, engine mounts and original radiator. Thankyou for your help. Daniel
:212C:
Postby DasLandRoverMan » Mon Jul 22, 2013 7:07 pm
As mentioned, I'm by a self professed expert, but I do have a decent working knowledge of them.
Nutsaboutseries
Postby Nutsaboutseries » Tue Jul 23, 2013 12:16 pm
contact me anytime. Dont be offended if i take a while to come back to you as I get distracted from time to time with family stuff so kind of dissappear for periods.
double ended fuel pump can be purchased new from burlen but you'll need to fabricate the chassis bracket or you can use carb facet type as per classic range rover and later 6 cyl ser 3.
I'm pretty sure I've got the taller airbox. I know I've got an accelerator linkage stored somewhere really sensible after taking off a scrapper. just have to find it.......
1972 109" SW
1970 109" SW
1970 109" 1 Ton
1967 109" 6 cyl
1967 2b FC 2.25D
1963 2a FC 2.25P
tarndale
Postby tarndale » Wed Jul 24, 2013 8:50 pm
Rover 2.6 and 2.9 big end bearings - ten thou under
Not sure if these things are hard-to-find or not:
http://www.trademe.co.nz/a.aspx?id=618937138
If anyone is desperate I can buy them and post onwards.
Neil
DML
Postby DML » Sun Jul 28, 2013 4:40 pm
Nutsaboutseries wrote:contact me anytime. Dont be offended if i take a while to come back to you as I get distracted from time to time with family stuff so kind of dissappear for periods.
Thankyou very much Ben that's very reassuring to know and thankyou all for your help so far!
:212C:
Postby 22900013A » Sun Jul 28, 2013 5:03 pm
:212C:
Keeping 1-Tons/FCs on the road, or returning them to road, is what it's all about!
Users browsing this forum: No registered users and 19 guests
