101 rims
Drum
101 rims
Postby Drum » Fri Dec 06, 2013 5:39 pm
I have 5 of these six stud rims. I could do with some 6.5 inch rims for the tacr and was considering two options.
1 - sell the 101 rims to fund a set of 204s or similar.
2 - drill the rivets out and weld in 5 stud centres.
Opinions on these crazy ideas welcome.
Re: 101 rims
Postby Wheeledbeast » Mon Dec 09, 2013 9:19 am
Wont you have all sorts of alignment/balance problems if you try to change the centres :?:
Re: 101 rims
Postby 22900013A » Mon Dec 09, 2013 9:23 am
I thought cutting the centre out and replacing it was known as "banding" and is illegal?
Re: 101 rims
Postby DasLandRoverMan » Mon Dec 09, 2013 6:22 pm
Banding is cutting a rim in half an welding a piece of 'tube' in the middle to make it wider.
What you're thinking of is possible, although given the comparative rarity of 101 rims, I'd sell them and find something else to put a set of 5 stud centres in, be it a set of Disco steelies or perhaps some 8 spokes.
You can often find people giving the Disco ones away...
Drum
Re: 101 rims
Postby Drum » Mon Dec 09, 2013 10:42 pm
DasLandRoverMan wrote:Banding is cutting a rim in half an welding a piece of 'tube' in the middle to make it wider.
That's a good idea. :DD
Anyone want to buy some 101 rims?
JPC
Re: 101 rims
Postby JPC » Tue Dec 10, 2013 6:02 am
Drum wrote:I have 5 of these six stud rims. I could do with some 6.5 inch rims for the tacr and was considering two options.
Re: 101 rims
Postby DasLandRoverMan » Tue Dec 10, 2013 7:41 am
Oooh, smart!!!
Drum
Re: 101 rims
Postby Drum » Tue Dec 10, 2013 8:19 am
Cheers JPC 8-)
135H
Re: 101 rims
Postby 135H » Tue Jan 14, 2014 7:14 pm
Stab in the dark: would 101 hubs/drum fit on a series stub axle?
cow mop
Re: 101 rims
Postby cow mop » Tue Jan 14, 2014 8:22 pm
hubs are bigger
how much do you want for the rims?
Users browsing this forum: No registered users and 65 guests
