Tie rod rubber underneath the gearbox
1960SeriesII
Postby 1960SeriesII » Mon Apr 25, 2016 6:51 am
The "So you think you know Land-Rovers..." topic has got me thinking - the rubbers on the tie rods beneath the gearbox are shot, would need replacements but can't find any available. Does anyone know a source? I could not find part no. in the catalogue as the rubbers are either not there or are hiding in a section in which I wouldn't go looking for them...
Re: Tie rod rubber underneath the gearbox
Postby helicalrider » Mon Apr 25, 2016 7:25 am
http://www.lrseries.com/shop/product/li ... UFFER.html
Perhaps this parts work too. But i`ve no info about the measures.
http://images.google.de/imgres?imgurl=h ... 9&biw=1239
Cheers Marc
1960SeriesII
Postby 1960SeriesII » Mon Apr 25, 2016 9:42 am
Cheers, will take a look at mine as those on my truck look different-shaped, but it may be due to their deterioration.
Postby lanceley » Mon Apr 25, 2016 11:26 am
I got mine from Tony Arnold at Land Rover Fasterners
Postby DasLandRoverMan » Mon Apr 25, 2016 5:16 pm
They're the same as the smaller size lower bushes for 109 rear shock absorbers aren't they? The ones shaped thus;
__
)__(
If you get the idea from that? They're also useful for the top of the ARB links on the front of a IIB also.
Postby DasLandRoverMan » Mon Apr 25, 2016 5:18 pm
Just read the links, seems not.
They do work for the Anti Roll Bar though.
udo1-ton
Postby udo1-ton » Tue Apr 26, 2016 5:36 pm
1960SeriesII
Postby 1960SeriesII » Wed Apr 27, 2016 6:32 am
Cheers, much appreciated, apparently the main problem was my ignorance of how it's called - the actual availability of the part doesn't look that problematic :lol:
