FC engine swap
Posted: Mon Mar 21, 2022 4:35 pm
I could do with some advice on an engine chane in an FC please - I get this is not an uncommon question but my truck is weird so things get really hard.
Basically the fire engine body is built around a steel frame - its coach built double skinned, ply on the inside, ali on the outside - the problem is the steel frame is WELDED to the chassis, there is no way of getting it off without serious destruction.
This means any engine has to go up between the chassis rails, so, assuming the engine is bare, what goes up? Tdi, TD5 and/or a '38 diesel?
Any help sincerely appreciated
