Posted: Sat Apr 29, 2017 2:14 am
For 'pledge' 'Marc' in Germany and 'Marco' in Italy.
Disc kits with Deep Rims here:
viewtopic.php?f=7&t=1736&p=11102#p11102
[1] Deep Forward Control One Ton Wheels Rims
Fuckwit's Lipsmackin’coolfizzin’rivet countin’anorakin’motivatin’coolbuzzinn’hightalkin’fastlivin’evergivin’rewritin’grousin’self-aggrandisin’,
Buyers' & Sellers’ Guide to Land-rover Super-Heterosexual Deep-Dish, 2B, Forward Control, One Ton, 130, Rims & Wheels. 543384; 569203; 569204; ANR1534
It contains several large errors and remains in what has since become a 'Registered Users Only' forum, more info comes to light, this is a rewrite of a post I did on that forum some four-five years back. (The things I do for you, honestly)..
Are you sitting comfortably? Then we shall begin:
I know, I know, sob, and it's no use. You've been doing it for years, a trail of bread-crumbs at the wheel-arches every morning - gently coaxing those rims out.
Now you want a set of FC or one ton rims? This term is a very broad brush. If we're going for pedantry, at nine variants and counting with part numbers duplicated to very different rims, there's not really any such thing.
You'll need to know what you mean. Your first mistake would be to assume rims were assigned an orderly model or part number.
These things were manufactured in the 'Land of, "Oh, that'll do." ', the West Midlands. The factory has been mixing rims from the start. The idea there's neat order to something not made with precision from the off, is just wrong. And owners? There's also been infinite swapping - hence you can hold a 'matching-numbers set' yet easily have a dog's-dinner.
The above Portuguese One Ton is a good example. This example left the factory wearing Pressing D Rims, (Part No. 569203). There's numerous anomalies meaning you can't attribute part numbers to one vehicle. Famously sought, part 569203 doesn't exist in the parts book. As for the numbers that do, these were thrown at anything. There's strong evidence, quite a few vehicles left the factory with odd rims.
It's too easy to F this up. The rarer rims are often found without part numbers. Don’t fixate on numbers, unmatched or missing numbers is often a good thing.
How the Leafer got its Deep-dish Rims
Oh best beloved, the G**gle Poodle will find a heap of useless bullplop on this subject.
Paste this into Google and you'll see what I mean:
(Landrover OR “Land-rover" OR “Land rover”) (2B OR 569203 OR 569204 OR ANR1534 OR 543384 OR Forward Control” OR “One Ton” OR 130) (Rims OR Wheels)
Running Pressing D Rims on a Stagey.
Are they all the same? Far from it. Along with a part number mess-up, the truth lies in parallax and optical deception, I’ll explain. Viewed square-on or close to it, these rims ‘appear’ identical. In the flesh you’ll see big differences. Equally, in removing binocular vision, a few iffy snaps on eBay (most likely where you’ll be buying) can deceive massively. All is revealed when you see rims in the flesh.
The ‘Pinpointer shots’
It’s not easy to verify these rims and too easy to be hood-winked. You won't usually have the rims before you.
Usually missing, you’ll want shots showing each inner tyre-well (to see the rivet position) and each hub-side. Often sets are mixed, so you’re after shots for EVERY rim. More likely, you’ll be given 3-4 shots, one a stamped part number for a single rim, the rest from the valve-side. Yet none of the whole set.
If you now grasp the point I make, a mixed-set can be a VERY good thing...
The Winnower
Of the hub-sides of your rims, you want pix like this one. This allows you sight of the rivets, tyre-wells and hub-sides.
Seeing all the rivets help lots. You want to look at the tyre-well rivet positions. Valve-side pics tell you nothing.
What's wrong here? Are you sure you want the part numbers matching?
Most of you won't see what's wrong with the above. This is the classic duped-buyer scenario. As I write this update, these are available on eBay. The seller openly admits being duped into buying three different variants making up his five rims. All were sold as the same thing. Four have the same part number. You'd easily see the problem in the flesh. By the end of this thread, even via poor photos, you'll grasp these differences. Briefly, from the left, the left rim differs from the two in the middle and yet again from the two on the very right. Hence, 1 + 2 + 2 rims. No three the same, and certainly not all five. Land-rover used the same number across several rim types.
From the left there's one rim part numbered, either ANR1534 or 569204, the two in the middle numbered either 569204 or 569203. Whereas on the right you have two rims numbered 569203.
So from the piccy, because of part number overlaps, you can conclude you have four possible permutations.
Perm 1 ( 569204 x 3) + (569203 x 2)
Perm 2 ( ANR1534 x 1) + (569203 x 4)
Perm 3 ( 569204 x 1) + (569203 x 4)
Perm 4 ( ANR1534 x 1) + (569204 x 2) + (569203 x 2)
Which is why you need your eye not on the numbers, but on the pressings. This I will cover.
Here, from the left, you're looking at:
Pressing A x 1 + Pressing C x 2 + Pressing D x 2
"They're all the same see, there's only 1/2 inch in it, etc etc."
Yeah right.
A ruler helps, yet in isolation, won’t be a practical method to finger each rim either. You’ll need other indicators. Confronted with a photo, ridden with parallax, I still struggle.
Part Numbers won’t work
There was a festival of complaints about that first post being long. Many insist this subject will be wrapped-up in a few part numbers and a cosy fireside diagram. It can't.
This image notes 569204 as a part number, whereas the famed 569203 is not listed at all. Parts numbers are an attempt to bring order to something never adhered to in the first place.
There's abundant evidence our fabled One Ton or FC rims became a mess of whatever the factory stocked on the day. Part numbers do help, but only to winnow rims down to pressings.
No apologies ( and you’re bored already) this rewrite is not shorter.
All LR rims including the 6.5 J rims have their hard to see part numbers (they get filled with paint). stamped on the inter-stud flats. Then again, some have NO stamping...
Anorak on, whether you're after train-spotter-originality or 'Wikid bruv, propa wideboyz weeeils innit' you're going to be spending £500-600 upwards. Whilst several hundred must survive I’m aware of only sixteen sets of the ultra-rare and desirable late 2B Forward control rims. With only hundreds ever made, and few survivors, it’s not pub-talk, £1500 is about the going-rate for a full set of the rarest. Cost is not the problem. It’s finding them. The price gouging on rare parts has further to go.
The Archbishop of this parish and his lovely unmolested One ton complete with super-rare 569203 Pressing D rims. Don’t reckon he’ll be parting with ‘em. Won’t let me have his winch either… git.
And rivet-counters like a number...
The Winnower
Yeah right.
