Postby Wheeledbeast » Sun Sep 11, 2016 6:58 am
started getting the new engine ready.
sump seems to be full of copper :?: any body any idea what that means :?: it is a little bit concerning :?
Postby DasLandRoverMan » Sun Sep 11, 2016 7:27 am
Pull some bearing caps and see what they look like. Eminently possible that the 'copper' is bronze from the bearing shells which have worn through the white metal.
Postby Wheeledbeast » Sun Sep 11, 2016 5:42 pm
:? :( hmm not so good then. May be i should cheer my self up by combining the previously fitted checker plate with a massive cow catcher :)
where can i get some cibies with lense covers from :?:
Postby DasLandRoverMan » Sun Sep 11, 2016 7:02 pm
Cibies? Noooo, KC Day lighters with the smiley face covers!!!
Postby Wheeledbeast » Tue Sep 13, 2016 10:02 am
Had a look at one of the main bearings, and although it showed a small amount of wear, it looked pretty good to me. Ill try and have a look at the big ends. does any one know of an oil flow diagram :?: whitch bigg end is furthist from the oil feed?
Postby DasLandRoverMan » Tue Sep 13, 2016 4:06 pm
The ones at the back usually take the most load, and are therefore more prone to wear.
For the sakes of an extra 2 nuts to drop another cap why not pull 2?
Postby Wheeledbeast » Wed Sep 14, 2016 4:09 pm
:D Big ends in good condition, probably better than the main bearings. Hard to even tell they have been used :D . fell much better about that now still not sure about the copper stuff though. :?:
Postby Wheeledbeast » Tue Nov 08, 2016 10:32 am
No progress since the last post struggling to find the motivation to get out in the cold and the dark to mess with it. :(
Postby Wheeledbeast » Thu Mar 09, 2017 11:33 am
Still no progress :( and the Fc is staring to turn green and look very sorry for its self. The sun is shining now though so may be i can summon up the enthusiasm to get out their and do some thing. :?
Postby Wheeledbeast » Fri Mar 17, 2017 10:26 am
I am not sure if this counts as progress, but i have put the battery charger on :?: may be a sunny weekend will yeald some progress. :?
Users browsing this forum: No registered users and 75 guests
