Starter motor
col
Starter motor
Postby col » Sun Oct 04, 2015 5:26 pm
Having finally found a suitable replacement starter motor for the 11b a reconditioned unit I was extremely happy until the tape measure came out :o The margin for removal being tight at 100mm between the chassis and sump housing, on removing the old unit a pry bar was inserted into front engine mounting and I was able to get approx 3mm more play. the old unit 100mm the new unit,115mm . After a day wrestling under the landy 2 jacks on top of each other, not recommended the bloody motor is in. :)
col
Re: Starter motor
Postby col » Sun Oct 04, 2015 5:27 pm
col
Re: Starter motor
Postby col » Sun Oct 04, 2015 5:29 pm
Re: Starter motor
Postby Wheeledbeast » Mon Oct 05, 2015 7:41 am
I had the same problem with my starter. I had to disconect the gearbox mounts and move the whole gear box over to get clearence to get it past the flange for the sump :evil:
col
Re: Starter motor
Postby col » Mon Oct 05, 2015 5:23 pm
Same here, at least the old girl is running again after 18 months standing :) tappets next she sounds dreadful.
col
Re: Starter motor
Postby col » Fri Oct 09, 2015 6:12 am
Any advice please on setting the correct valve clearance , I read somewhere that removing the exhaust manifold was involved in the correct procedure. I don't fancy fettling with a hot manifold if not needed. In the copy I have of the owners manual there is no mention of this but is very vague on the subject.
Re: Starter motor
Postby Wheeledbeast » Fri Oct 09, 2015 3:40 pm
Das can probably offer the best advise , but if you dont remove the exhaust manifold it is very diffficult to get the exhaust valve rocker back on with out any leaks i had an almost unnoticeable leak on mine, but by the time i had got from home to Dunsfold ( 150 odd miles) I had lost nearly two gallons of oil, and rust proofed the rear half of the chassis :cry: . I am sure the valve clearance is hot or cold. :?:
udo1-ton
Re: Starter motor
Postby udo1-ton » Fri Oct 09, 2015 3:49 pm
Only the inlet valves have to be adjusted in hot condition, the exhaust valves cold.
If you want to do a proper job the exhaust manifold has to come off.
I did it once a year and greased the studs with loads of copper paste. No problems anymore :D
col
Re: Starter motor
Postby col » Fri Oct 09, 2015 4:27 pm
Thanks for the replies , exhaust manifold will be removed. :DD
Users browsing this forum: No registered users and 14 guests
