Were SU or Strombergs fitted to the 2.6/3.0 Six?
Postby fuckwit » Fri Jun 22, 2018 11:12 am
LRs generally have issues with the various flavours of Weber, Zenith and Strombergs fitted to 2.25 & 2.5 engines. Whole threads on carbs witter on about this carb or the other. Agreed age doesn't help, yet other marques don't have quite so many problems. I fitted an ACR SU conversion to my 2.5 and have never looked back.
Browsing various places I keep hearing mention of the 2.6 fitted with SU carbs? I thought, even in 'Auntie Rovers' the 2.6 six cylinder left the factory gates with Strombergs. Is the SU a conversion, or did some variants have these?
Th0ma_s
Re: Were SU or Strombergs fitted to the 2.6/3.0 Six?
Postby Th0ma_s » Fri Jun 22, 2018 12:39 pm
My 109 2.6 have a Stromberg 175cd.
So did mye spare engines until i took them of to rebuild the best one of them.
Postby fuckwit » Fri Jun 22, 2018 3:29 pm
Yes, that's what i thought. Solihull, for whatever reason, always fitted everything else. Never an SU?
Postby DasLandRoverMan » Sat Jun 23, 2018 8:14 am
I've seen a few sixes with the SU on them, both 2.6 and 3 litre flavours, although all in Forward Controls, which also got a Stromberg from the factory.
I think part of the reasoning was to do with SU's suffering fuel starvation running at more 'extreme' angles, which the Strombergs didn't get.
Car V8's had SU's from the word go, whilst the Land Rover ones had Strombergs up until the late 80's.
Boehler
Postby Boehler » Sat Jun 23, 2018 9:04 pm
My FC IIB 2.6 petrol got a SU mounted , plate on it says AUD81.
Considering the low mileage and general unmolested state of the vehicle i think this is its original configuration.
Apart from that, the Parts catalogue says so :-D
best regards
Alex
Postby fuckwit » Sun Jun 24, 2018 9:06 am
I had heard the SU wasn't so good at extreme angles, WW2 Spitfires were fitted with a form of SU, which was a disadvantage against the fuel-injected opposition.
Despite the "No good on inclines" trope, almost the complete British Leyland car line-up at the time had SUs. I did wonder why some didn't stray to Rover. Seems they did.
In a leafer, at angles where this matters, can't see it myself, you will have already fallen out of the thing.
My 12YO boy likes to sit out back, tail-gunner position. Next time I pull negative G with a BMW on my tail, I'll let you know.
Postby 22900013A » Mon Jun 25, 2018 5:09 pm
As well as FCs, early bonneted sixes had the SU.
Postby helicalrider » Wed Nov 07, 2018 10:26 am
Early 2,6 Station had SU HD6.
Later they had Stromberg/Zenith 175.(The 2.6 was introduced in May of '67 with a single SU HD-6... then in June the SU was replaced with a Zenith 175 CD-2S)
FC also had SU HD6.
109 2,6 NADA and Rover P4 110 had Weslake with SU HD8.
Rover P5 3.0 MKI had SU HD8.
Rover P5 3.0 MKII and III with Weslake also had SU HD8.
Regards Marc
