Barn Find 1970 GPO IIB Broadcast
Share photos and info about your Series 2 FC
Scoguy84
Postby Scoguy84 » Sun Apr 01, 2018 10:07 pm
Image[/img]Image
Found mid 2016 collected a year later mid 2017 Light Restoration work carried out so far preserving as much originality. Removed water pump had it rebuilt original pump fully and housing. Inside the block is like new so smooth inside the water jackets. Milage is genuine. Fired the engine up Aug 2017 its run since 1991. pair to that turned over by hand plenty oil etc. compression doubled after 1st run with zero smoke. Video to prove :) I was not even looking for a Land Rover went to look at another car. spotted the Land Rover went back a year later to look at the car again and asked about the LR when the owner mentioned the milage I bought it on the spot :) Latley just been replacing seals and gently recomissioning. A touch of welding to rear of chassis, new springs 100 each next town where i live. Inside the chassis is like new. Outer chassis showing a black base coat with the GPO silver. most fallen off plenty oil will keep it good.
Fleet number in black and white pic is 204633 My GPO Fleet number is 204627 built 1970 registered 1972.
I managed to save what was left of the gold leaf lettering by gently scraping with a blunt rounded screw driver took ages.
After a cooling fan blade, the driveshaft to water pump and the bearing bracket support / mounting.
When can I find replacement top and bottom coolant pipes? Any suppliers I can contact?
I also will eventually return to separate cab. I would need a top and a rear cab parts.
If any one has a similar GPO Broadcast van I would love some measurements and detail shots of the folding step. I would like to make up reinstate the side step.
Any info is appreciated :)
Screen Shot 2018-04-01 at 22.38.04.png (180.64 KiB) Viewed 564 times
Scoguy84
Re: Barn Find 1970 GPO IIB Broadcast
Postby Scoguy84 » Sun Apr 01, 2018 10:19 pm
Gold leaf lettering revealed.
Original wheels powder coated
Cut out rot but keeping as much original metal.
finished repair
SO far so good Next fuel system and tank to Fush out and tidy up the rear electrics. A final service tappets etc to do and fresh oils.
Scoguy84
Postby Scoguy84 » Sun Apr 01, 2018 10:41 pm
Front axel nearly done stuck a Original wheel with once of the original tyres as a spare on. waiting for the New tyres. I don't mind the Fairy freewheel hubs. just stripping and cleaning.
Scoguy84
Postby Scoguy84 » Sun Apr 01, 2018 11:11 pm
Jack box bulkhead is in very good condition.
Tools jack is practically new.
linesrg
Postby linesrg » Tue Apr 03, 2018 5:40 pm
Scoguy84,
Seems we both have a very similar vehicle????? You can PM me if you want.
Regards
Richard
1949 80", 1950 80" Mobile Welder, 1951 80", 1952 80", 1952 86" Prototype Welder, 1953 ALRC trialler, 1957 88" fitted with a Turner diesel, a FC 2B, Stage One V8, a 04 plate Discovery II and a 1990 20V Audi quattro.
Postby 22900013A » Sun Apr 29, 2018 4:23 pm
I assume the cab is open into the back body? Could this have been a GPO modification?
Scoguy84
Postby Scoguy84 » Mon Jul 09, 2018 9:28 am
A couple of photos of its current progress fuel pump to fit and a little detail welding on the outrigger gussets to finish.
Eating on new Documents taking a while but almost there. Been fired up from time to time runs beautiful a final tune up and valve adjustment to do.
Scoguy84
Postby Scoguy84 » Mon Jul 09, 2018 9:30 am
The 569203 wheel just visible all are matching from new.
Scoguy84
Postby Scoguy84 » Mon Jul 09, 2018 9:33 am
I decided to give the chassis a similar black finish. GPO then painted over with silver paint.
Postby 22900013A » Mon Jul 09, 2018 6:23 pm
Where are the tyres from?
