18A, a six cylinder IIB
Share photos and info about your Series 2 FC
Postby DasLandRoverMan » Tue Jun 03, 2014 6:13 pm
Some of you will have seen this vehicle before, for those that haven't a brief history.
18A is an early 1966 truck, after leaving the production line it made its way across the factory ground to Special Projects.
It was first registered for the road in 1968, and received a new registration mark as was procedure at the time, resulting with its current F suffix plate.
It was likely converted to a breakdown truck in 1979 judging by its last 'date of liability' after which it would have run on trade plates in its breakdown role with a company called Milton Motor Body Repairs in Sittingbourne, Kent.
The phone number on the doors (with an added 1) is still current and connects you to a bodyshop called 'Pomphreys'.
It's likely to have been retired before 16th April 1995 (when UK dialing codes changed to the 01 prefix) and was advertised in LRO classifieds during 1996 as 'ideal for renovation'.
It passed to two owners before I bought it from the previous owners widow as she dealt with his quite considerable collection of Land Rovers.
I set out with intent to rebuild, and did a bit of work with it but was very restricted by time and money.
It is now however undergoing rebuild for another forum member -I'll let him announce himself- to add to his collection.
Anyways, some pictures of the job sofar, starting from how she looked with around 50% of the extra steelwork added for the breakdown truck conversion removed.
The rest of the extra weight can be seen welded on the back.
Imposing sight from the bottom of the pit.
Extra metalwork gone.
Rear body off, new -somewhat better- top chassis just visible behind.
Coming apart.
Bulkhead actually pretty good.
Cab and bulkhead off.
Stripping cab down to component parts to allow cappings etc to be regalvanised.
Chassis with extra bits cut off and hit with a needle gun and wire brush looks reasonable.
But still in need of repair post sandblasting.
New metal let in sympathetically, utilising original edges and seam welds to prevent it ending up like a patchwork quilt.
The plasma cutter is an absolute godsend for this job.
Spring hanger repaired.
And even some new rear shock absorber mountings.
I'll continue this with some pictures of the finished chassis, whilst you'll have already have seen the replacement engine - a more economical option than sorting the siezed original at present- in the FC engines thread.
We have a complete dropside rear body for it, along with a few other bits and pieces that will allow it to come together into a nice presentable vehicle.
Stay tuned for the next exciting episode...
Jeremy
Re: 18A, a six cylinder IIB
Postby Jeremy » Tue Jun 03, 2014 7:26 pm
I really like that vehicle! Watching with interest!
parksy64
Postby parksy64 » Tue Jun 03, 2014 8:09 pm
Great stuff!
Postby Wheeledbeast » Thu Jun 05, 2014 5:25 pm
Some neat looking fabrication going on there, not like my pigeon poo efforts :!: :)
Postby DasLandRoverMan » Thu Jul 03, 2014 7:54 am
Things are progressing well, just haven't had time to organise and upload a photo update.
Something of interest, I've found the Axle numbers are in the '325' sequence, which was the sequence used for home market 2.25 petrol powered trucks, of which there are only records of one being assembled.
Not exactly a useless snippet, might be of interest to some.
Postby DasLandRoverMan » Thu Sep 01, 2016 5:43 pm
So, it's been a while since this thread was updated, progress hasn't been as rapid as first hoped, and severely disrupted by a split with my now ex-wife, and a move to Cumbria, but it's starting to get somewhere now.
Anyways, after the chassis was repaired, it was ready to go for galvanising.
It looked terribly shiny upon its return.
Put together the right way up and starting to turn black.
Sat up on its axles and the bulkhead sat on to begin looking at repairing it.
However, after being attacked with the wire brush on the angle grinder it was discovered that despite looking half decent on the surface, it had quite a lot of rot issues.
This prompted the start of a sideline project, which has taken a bit of time to work through, but is now bearing fruit. A lot of time spent measuring, reverse engineering and CAD drawing followed by some metalwork has seen this start to take shape.
Yes, you are looking at a Series II bulkhead made in 100% new steel.
Further CAD work saw a nice heavy duty steering relay locating plate.
Mounting brackets for the rear lights.
And some new mounting brackets for the rear of the cab.
Whilst there's also a nice pile of freshly galvanised parts waiting for it.
And paint going onto the panels, in this case standard 'Mid Grey' from the Paintman.
Finally feels like we're getting somewhere.
Trebro
Postby Trebro » Sat Sep 03, 2016 6:00 am
Some impressive bits of fabrication there Das
Postby 22900013A » Sat Sep 03, 2016 7:05 am
Good work, nice to see some movement.
Postby Wheeledbeast » Sat Sep 03, 2016 7:46 am
wow there is a lot of work there :shock: looking good though, love the spangaly fresh galvanize. :)
Users browsing this forum: No registered users and 5 guests
