2a FC rear cross member
Share photos and info about your Series 2 FC
NZ2AFC
Re: 2a FC rear cross member
Postby NZ2AFC » Sun May 10, 2015 1:00 pm
More questions........
I am getting the last of the welding repairs done on the chassis.
The bracket that holds the spare wheel clamp onto the chassis out-rigger. The parts book shows two holes for the bolts (first photo) but only list 1x 4-3/4 inch bolt.
My chassis (second photo) has one hole in bracket but two in the chassis, spacing is closer that the parts book illustration. Which hole is correct? Can someone post a photo how the chassis should be.
My 2A chassis number is 28700207a.
Thanks.
Leon.
Holes as show in parts book
Wheel clamp.jpg (166.9 KiB) Viewed 8263 times
The holes that are in my chassis
Wheel clamp bolt holes-ss.jpg (28.77 KiB) Viewed 8263 times
1993 R-R Tdi
Postby 1960SeriesII » Mon May 11, 2015 5:19 pm
This is what it looks like on mine:
Perhaps the two set of holes on the outrigger were there to adjust the bracket based on wheel size? On the other hand, the bracket I have there has a plate inside it that does not seem to allow any other position than the one it is in now.
parksy64
Postby parksy64 » Tue May 12, 2015 7:35 am
Mine looks like this (28600006):
NZ2AFC
Postby NZ2AFC » Sat May 16, 2015 2:42 am
Thanks guys.
Just to confirm, the distance from my two holes back to the main chassis rail are 256mm & 280mm.
Which of the two measurements do you have?
Distance from hole to chassis.
Wheel clamp bolt holes-ssy.jpg (36 KiB) Viewed 8209 times
1993 R-R Tdi
Trubster
Postby Trubster » Sat May 16, 2015 11:37 am
Hi. I have followed the discussion about the wheel clamp with interest as mine appears to be messed about with....my outrigger also has two holes....one at 256mm and the other at 275mm....the one at 275mm looks less original....so I would suggest that the 256mm one is correct.
parksy64
Postby parksy64 » Sat May 16, 2015 6:21 pm
Will get back to you on monday
NZ2AFC
Postby NZ2AFC » Tue May 19, 2015 7:33 am
Thanks 'parksy64' will await your reply.
If you (or anyone else) has the original battery tray, there is other measurement that I need. The vertical height of the tray LH bracket. See photo attached.
Leon.
Battery tray.jpg (23.87 KiB) Viewed 8167 times
1993 R-R Tdi
Postby 1960SeriesII » Tue May 19, 2015 6:03 pm
25.7 cm from main chassis rail for the hole in the spare wheel clamp outrigger, 23.5 cm from top edge of tray to tray bottom (upper edge of the bottom tray plate) or 23.9 from top edge to tray bottom edge.
Chassis no. 30300575, build date 14th June 1966.
parksy64
Postby parksy64 » Sun May 24, 2015 10:48 am
Here is mine with the tape
NZ2AFC
Postby NZ2AFC » Thu Aug 27, 2015 11:29 am
All three parts of the chassis are on their way to the 'dip stripping tank' and then the 'hot dip galvanising tank'. This will cost me an arm & leg. Will see what its like when it gets back.
1993 R-R Tdi
Users browsing this forum: No registered users and 6 guests
