2B crew cab build thread
Share photos and info about your Series 2 FC
watson32
Postby watson32 » Mon Dec 17, 2012 5:54 pm
Eventually got round to sorting the build thread out on the new forum.
At the beginning of this year i bought a 2B as a project (most bits came in the pick-up haha)
To make it a bit more practical i decided to fit a 300tdi engine and box out of a 110. At the same time i thought a crew cab would be a bit different so set to making the body work out of what was left of our 110.
To make it all fit (the turbo was the main issue under the seat box) we had to lift the top rails up. I made some 4" rails (the same as the original one) to go between the chassis and top rails.
I've had it all together with bits tacked in place to allow me to sort all the steering linkages out and have now stripped it back down to weld all the brackets / mounts on and paint everything up.
Will hopefully have a few more photos of progress soon.
Re: 2B crew cab build thread
Postby DasLandRoverMan » Mon Dec 17, 2012 6:05 pm
Looking good, I'll be interested to see more progress.
Are you fitting power steering, and if so what's the plan?
watson32
Postby watson32 » Mon Dec 17, 2012 6:38 pm
Thanks.
No i've ended up using a 101 steering column and modified the mounting points to suit the 110 bulkhead.
Postby DasLandRoverMan » Mon Dec 17, 2012 8:02 pm
Good call. Does it leave the wheel in a decent position?
More importantly, does the wheel turn easily with the steering connected?
col
Postby col » Tue Dec 18, 2012 5:40 pm
A crew cab fc looks great ,good choice there.Is the gs a runner or a project to
watson32
Postby watson32 » Tue Dec 18, 2012 7:19 pm
The wheel feels like its in a good position (not too low to catch your knees on) and it seems to work ok but will let you know once its up and running.
The 101 is my little brothers project, it was on the road until a few months back (i've just posted a build thread in the 101 section)
watson32
Postby watson32 » Mon Feb 18, 2013 10:30 pm
Have eventually got round to doing some work on the 2B
The chassis is all ready to start fitting bits back onto it.
Bit of strengthening to make up for the parts i had to cut out to fit the 300tdi in.
300tdi engine mounts
Still need to finish the rear member off yet
watson32
Postby watson32 » Fri Mar 08, 2013 7:14 pm
Think the 2B might have to stay in bits for a bit longer.
Bit of a new toy that arrived today
http://www.900club.org/viewtopic.php?f=26&t=303
watson32
Postby watson32 » Fri Jul 17, 2015 9:19 pm
well we eventually have a bit of time to get back on with the 2B
small steps at the moment but managed to get hold of a crew cab roof, hopefully will be able to start the slow process of putting it toghther soon
parksy64
Postby parksy64 » Fri Jul 17, 2015 9:26 pm
Good to see it moving again
